NDC S-10 fuel pump product
1 following
info@natedogcreations.com's avatar
NtotheIZZATEDOG's avatar
NtotheIZZATEDOG
Edited: 6/1/2009 3:49:50 PM by NtotheIZZATEDOG
 New product from NateDog Creations This is a brand new item we are producing to help eliminate the difficulties of running the factory S-10 fuel pump with an aftermarket or custom fuel cell. The unit is available as a weld-on or bolt-in product. The base and split clamping ring are CNC machined from 6061 aluminum while the fuel pump retaining ring and hardware are 304 stainless steel. Two large fuel compatible o-rings locate inside machined grooves to ensure a leak-free seal. The fuel pump receiver base mounts on the topside of the fuel cell and the half clamps are mounted from the inside, which sandwiches the fuel cell skin in-between.
Please check measurements to confirm if your fuel pump is compatible with this product. Largest O.D. of the mounting flange is 4.450" or slightly larger than 4-7/16" The O.D. of the ring which the factory o-ring slides onto is 3.700" or slighty larger than 3-11/16"
Pricing -
Weld-in unit $79.00 (includes Fuel Pump Receiver, Retainer Ring and Retainer Ring hardware)
Bolt-in unit $119.00 (includes same items as Weld-in unit plus Split Clamping Ring, O-rings and all necessary hardware)
 Compared to the cost of an in-line fuel pump conversion, this product offers great value. Installation allows use of all factory equipment, including fuel gauge, without the expense and hassles associated with an in-line fuel pump.
Orders -
Call 215-361-1134 or email sales@natedogcreations.com" target="_blank" rel="nofollow">sales@natedogcreations.com We accept Visa/Mastercard/American Express and Paypal. (info@natedogcreations.com)
Thanks, Nate
Natedog Creations
www.NateDogCreations.com
